My student license for Creo 3.0 just recently expired. I tried to go in and reconfigure it. However, following the instructions on the online PDF in some of the other support blogs, I could not find the reconfigure.exe application. I searched the bin and the entire PTC folder in my program files. Do I need to uninstall and reinstall or is there another way?
if you have a copy of installation media on your PC, then uninstall/install could be the easiest solution.
MH
MH
