Creo 2.0 Student-Version doesn´t open
ptc-6716254
1-Newbie
Hey guys,
I have a problem with my Creo 2.0 Student Version. Everytime I try to open the program, it takes around 15 Minutes until the creo-window opens.. I can see the process of Creo right after I clicked on the icon. Does anyone have the same problem or a solution?
I´m using Windows 7 with an i5 4570 and 8GB Ram, should be enough for Creo.
Best regards
Oliver
6 REPLIES 6
MarkCheli
6-Contributor
(To:ptc-6716254)
Oliver,
That is interesting, are your graphics drivers up to date? That may be part of the problem, but it's hard to tell without getting a direct look at it.
I would also recommend submitting a support request here: http://support.ptc.com/appserver/wcms/forms/index.jsp?&im_dbkey=142574&icg_dbkey=482
This will allow us to get in contact with you more directly to diagnose this problem.
Yes, my graphics drivers are updated . I will contact the support. Thanks for your help.
The support sent me back to the forum...
Ok, everytime the window opens this warning appears:
Warning: Proper TCP/IP configuration was not detected
The TCP/IP protocol is not installed or configured properly.
MarkCheli
6-Contributor
(To:ptc-6716254)
Oliver,
Sorry for all the trouble this has been causing, can you email me directly at -. We'll do a remote session and get to the bototm of this ASAP.
Thanks for help, I sent you an email.
