Creo 2 does not open or run
ptc-4068784
I have just installed Creo 2 and I cannot get it running at all. Specifically, clicking shortcut icons or windows start menu icons does nothing, the only confirmation that I get from my computer that i clicked those icons is that I get a little loading circle by my pointer for about a second and thats it. Nothing opens, no apps launch, no processes or services lunch, nothing. I have triend reinstalling and I have tried updating my graphics driver and neither has helped.
Thank you.
I suspect that your installation is not complete. This can happen when using the web installer or when anti-virus and firewall protection is not disabled during the installation.
For the M070 build of Creo 2.0, the size of the folders at C:\Program Files\PTC\Creo 2.0 should be close to the following:
  • Common Files ~ 2.75 GB (16,017 Files, 665 Folders)
  • Parametric ~ 121 MB (211 Files, 47 Folders)
If your folders are smaller, I would suggest you uninstall and then reinstall using the full DVD download.
Adam
Hi Ido,
For Academic support, please see the PTC Academic Support forum. If you are unable to find a solution to your issue there, please submit an Academic Support Request.
Chris
I have same question with him
Moved this thread to as Christopher suggested.
Adam
