Creo 3.0 M110 Student Edition License Issue
Level 1
Hello everyone,
For some reason when I go to enter the license code it always fails.  I even tried using the relicense instructions and it still fails.  When I went to open Creo it gave me an error which I have taken a snapshot of and attached.  This is the current code that I am using- BK400407EDSTUDENTUNICL. Thank you for your help.
Tyler
Re: Creo 3.0 M110 Student Edition License Issue
1.]
C:\ProgramData\PTC\Licensing\BK390206EDSTUDENTUNICL_Iicense.dat file contains Creo Parametric 2.0 license (Version 33.0).
2.]
Look into C:\ProgramData\PTC\Licensing directory. Is there any other license file ?
If BK400407EDSTUDENTUNICL license file exists, then you can modify parametric.psf in Creo 3.0 installation to link it to this license file.
3.]
If C:\ProgramData\PTC\Licensing directory contains BK390206EDSTUDENTUNICL_Iicense.dat file, only then >>>
  • move BK390206EDSTUDENTUNICL_Iicense.dat file into other directory (e.g. C:\Users\youraccount\Documents)
    • this step will hide license file for relicensing procedure
  • run relicensing
4.]
Did you receive BK400407EDSTUDENTUNICL license file via email ?
MH
Martin Hanák
Hello Hanak,
I have the same problem as Tyler. I did all steps as you said.
To Step 2: In C:\ProgramData\PTC\Licensing are both license BK390206EDSTUDENTUNICL_Iicense.dat and BK400407EDSTUDENTUNICL therefore I moved the first license to my account as you said in step3.
But the Problem is the current licenseBK400407EDSTUDENTUNICL is expired as you can see in the following screen shot.
Is there any new licensecode for Creo 3.0 M110 and where can I find this one?
I see the Creo 2.0 license which I have moved out of the License folder.  However, I don't have the reconfigure utility anywhere in my Creo files.  I just uninstalled and reinstalled all of Creo and I still don't have it for some reason.
I guess that C:\ProgramData\PTC\Licensing must be empty (no files save in it), if you want to apply BK400407EDSTUDENTUNICL product code and get new license file for next one-year period.
MH
Martin Hanák
MH
Martin Hanák
Yes, you are right about there not being any files in that folder.  How do I get the license file with the code BK400407EDSTUDENTUNICL?
enter BK400407EDSTUDENTUNICL product code into orange field during installation. See Re: Can't get license. discussion.
MH
Martin Hanák
That code still gives me an error when entering it in the orange field.
error message is known issue. People reported this behavior in the past frequently.
If you'll wait for a while, license file should be emailed to your email box. You can save the file on disk and modify parametric.psf file to point to it.
MH
Martin Hanák
