Creo 3.0 Student License Renewal
Highlighted
Participant
I have been trying to renew my student license of Creo, and have followed the guides I found, but there is no reconfigure.exe program listed. What can I do to fix this?
4 REPLIES 4
Re: Creo 3.0 Student License Renewal
run the Setup.exe > select Reconfigure in the radio button list
you can:
  • uninstall Creo
  • remove files from C:\ProgramData\PTC\Licensing directory
  • install Creo
Martin Hanák
I have done that multiple times and kept getting the same error. So I ran the de-installer program and am trying to install again. Whenever I enter the BK39020STUDENTUNICL licence code, I keep getting a red error message.
there are several possible causes of the problem.
1.]
Installer is not able to detect network card.
Please open DOS propmt window, run following command and upload ip.txt file
ipconfig  /all  > ip.txt
2.]
BK39020STUDENTUNICL product code is obsolete
You can try to install Creo 5.0 to get current license file and then install Creo 3.0 using Creo 5.0 license file located in C:\ProgramData\PTC\Licensing directory
K-12       students can use Product code BE500806EDSTUDENTEDK12
University students can use Product code BK500806ED0790-Y3M9-4RW5
Also read:
http://apps.ptc.com/schools/references/install_creo5_schools_standard.pdf
https://apps.ptc.com/schools/references/install_creo5_unistudent_standard.pdf
Martin Hanák
Welcome to PTC Academic!
