Creo 3 Available
SOLVED
Newbie
Creo 3 Available
Looks like Creo 3 M010 is now available for Download!
Please confirm whether both Creo 2.0 & 3.0 can be loaded and run on same device?
Separate licenses needed or will Creo 3.0 license be usable by Creo 2.0 - backwards compatibility?
THX
Stu
Re: Creo 3 Available
This is correct!
You will need a new license, but as always it is a free license. So if you want to run both you should have 2 license files.
This is correct!
Welcome to PTC Academic!
