Creo 4.0 - License request failed for feature
Re: Creo 4.0 - License request failed for feature
hiiii
    sir,
   how can i solve it ??????
please give me right suggestions.........
Please do not use crack !
Martin Hanák
This happened because you are using a "pirated"/"cracked" license file.
I used the original license code and that failed I then deleted that code and added the path to the codes in my email and it says sucess next to it but I still get the error msg any advice?
in the installation setup process theres a box you can check to enable it not sure where exactly as I did this a few months ago but it shouldn't be hard to find
please attach picture showing error messages. Probably you will have to edit parametric.psf file manually to replace invalid information written in it by the right one.
Martin Hanák
 sir
my application show this error
please enlarge Warning Message List window to show us complete error message.
Martin Hanák
I'm having the same issue, I tried some of the solutions you suggested but none seem to work. Don't know if it has todo with the fact that I'm on Creo 5.0. Here's a Screen Shot of the license window that pops when trying to open Creo Parametric
I already pasted the License file sent to my email in the DVD file before installing with setup.exe
Don't know if thats exactly how its supposed to be done but I've already uninstalled and installed around 4 times and the same window pops in every Creo program I try to open.
Please help
Highlighted
Hello sir, please i can not use this licence : BK410705EDSTUDENTUNICL. it doesnt work on mine.
Welcome to PTC Academic!
