Creo 4.0 - License request failed for feature
Re: Creo 4.0 - License request failed for feature
@leprotht357 wrote:
Hello sir, please i can not use this licence : BK410705EDSTUDENTUNICL. it doesnt work on mine.
please do not use old discussions to report your current problem. Instead of it open new discussion. Also please provide detailed description of the problem (attach pictures, too). If you ask question "It does not work ..." then nobody can help you.
Martin Hanák
Good evening,
I downloaded Creo 5.0 and run the installation.
(Installed it first using the setup-trial, didn't work, so I uninstalled and installed again using setup.exe).
Like other people has experienced, once I open the Creo Parametric software, I get this error message about the license and everything closes.
Tried the re-installation.
And tried also to redirect, when installing, to the license that I have recived via email.
Didn't solve the problem.
Find attached the error message.
(Starting a postgraduate on product design soon and want to learn the basics before lessons begin).
please show me the contents of C:\ProgramData\PTC\Licensing directory, see example below
Martin Hanák
There's only one archive in the folder.
I understand it's the license.
BE410708EDSTUDENTEDK12_license.dat
C:\ProgramData\PTC\Licensing directory must be empty.
Uninstall Creo 5.0 again and follow instructions written in http://apps.ptc.com/schools/references/install_creo5_schools_standard.pdf document
Martin Hanák
Looks like it's working.
Thanks a lot for your time!
Really appreciate it.
It works !!!!! Thank you so much.
I tried about 10 times to install Creo 5.0 following the istructions of the document but I can't. For the firts buch un times i got the same error as Miuqs while trying to open the software (the problem with the lincense), but now after opening the setup.exe, when I try to Paste the License I get an error saying "error in license processing".
What should i do? Thanks
you are saying "when I try to Paste the License I get ...". This probably means that you have a file containing a license. "error in license processing" probably means that the file does not contains valid license. If you upload license file, I can check its contents.
Martin Hanák
