When downloading Creo 4.0 and booting up Creo Parametric, I could not use it as message popped up stating "License request failed for feature". This seems to be a recurring issue, but
not in Creo 4.0. Thanks for the help anyways. (By the way, this is the student edition).
@Brucco wrote:
When I try to paste the code in the box shown by the guide I get the error that I mentioned before.
I can add pictures taken from the pc but they are in italian Language. Is it a problem?
No problem, upload a picture.
Also show the contents of C:\ProgramData\PTC\Licensing directory (upload a picture of Windows Explorer).
If I try to search for C:\ProgramData\PTC\Licensing it says that it is impossible to find it
this is probably the root of your problem. Creo installer must be able to create C:\ProgramData\PTC\Licensing directory. I guess that you were not logged as admin user during installation.
dowloaded the file again making sure to be admin and still having the problem. The folder C:\ProgramData\PTC\Licensing also is still missing
create C:\ProgramData\PTC\Licensing directory manually and set Full Access for Everyone in Licensing sub-directory.
The above is my last idea ... I really do not know what's wrong with your computer 😞
It did not work, but thanks for the effort.
hiiii
sir,
how can i solve it ??????
please give me right suggestions.........
Please do not use crack !
I want to download Creo 4.0 on my computer. I want to know how to download the licensed software and how much will it cost? Please reply.
go to https://www.ptc.com/en/partners/partner-search , find PTC reseller operating in your country and contact him.
This happened because you are using a "pirated"/"cracked" license file.
