Creo 4.0 Student Edition License says "Success!" but also "Invalid file or format"
Raaid
Hi, the problem is as the title states. I saw another post explaining the same problem but with Creo 3.0. I'm trying to download Creo 4.0 but it's giving me an invalid file or format when trying to install license. Tried opening the file but was empty. How do I solve this? Thanks
23 REPLIES 23
SergeK
3-Visitor
(To:Raaid)
Having the same issue
MartinHanak
24-Ruby II
(To:Raaid)
see my reply from 2018-02-27 01:43 PM in https://community.ptc.com/t5/PTC-Academic-Program-Discussions/Licence-Issue/m-p/536850
I guess the problem is related to non-supported network card.
Please open Command Prompt window, launch ipconfig /all > ip.txt command and upload ip.txt file. I will check your ip.txt file and suggest you to disable suspicious network card.
Martin Hanák
TUANNM97
(To:MartinHanak)
I have the same problem
I have a similar issue. When i go into creo, it states that "License request failed for feature" and kicks me out of the software.
the error message tells you that creo is not able to find the proper license file.
Please attach a picture of error window (enlarge it to show the whole message).
Martin Hanák
phyzekiel
(To:MartinHanak)
Hey, same problem here.
phyzekiel
(To:phyzekiel)
I can't open ipconfig, for some reason.
I tried what you said in the other threads about deleting CREO (I didn't have it installed to begin with) and deleting the license file from the folder. Still didn't work.
I tried using advanced license entry to use the other network cards, they all have the same problem. I also tried disabling all my firewalls and VPN. Still not working.
Then I tried doing just the licence setup, still the same error with all 3 network cards.
  • Invalid file or format error message can mean, that the file is empty ... please check the file contents
  • Creo expects using IPv4 protocol ... I think you cannot use IPv6 protocol, only ... please check this
  • to run ipconfig /all command you have to open Command Prompt window and enter the command
Martin Hanák
phyzekiel
(To:MartinHanak)
Got it. Here's what I did before it finally worked:
  1. Install CREO (Even though it never fully opened due to no license)
  2. Uninstall all CREO software
  3. Run ipconfig /all from Command line
  4. Find network adapter with ipv4 option
  5. Disable windows firewall
  6. Run setup.exe from CREO download
  7. Run "Setup License"
  8. Select "Advanced License Entry"
  9. Select network adapter with ipv4 config info
  10. Select "Install Licensing"
I didn't try all the other possible iterations between these steps.
Anyways, it worked and I hope this helps others.
Thanks for the solid advice @MartinHanak
I had done all things u said but it still not working
file is empty, it using ipv4
MartinHanak
24-Ruby II
(To:ravan)
Martin Hanák
Hi!
I´m having the same issue as described above. Maybe you could help me as well?
I used this license code: BK500806ED0790-Y3M9-4RW5
The license file is empty.
Windows-IP-Konfiguration
Hostname . . . . . . . . . . . . : DESKTOP-8TIR3AI
Primäres DNS-Suffix . . . . . . . :
Knotentyp . . . . . . . . . . . . : Hybrid
IP-Routing aktiviert . . . . . . : Nein
WINS-Proxy aktiviert . . . . . . : Nein
DNS-Suffixsuchliste . . . . . . . : fritz.box
Ethernet-Adapter Ethernet:
Medienstatus. . . . . . . . . . . : Medium getrennt
Verbindungsspezifisches DNS-Suffix: fritz.box
Beschreibung. . . . . . . . . . . : Intel(R) Ethernet Connection (2) I219-LM
Physische Adresse . . . . . . . . : EC-8E-B5-3B-47-5D
DHCP aktiviert. . . . . . . . . . : Ja
Autokonfiguration aktiviert . . . : Ja
Ethernet-Adapter Ethernet 2:
Beschreibung. . . . . . . . . . . : Kaspersky Security Data Escort Adapter
Physische Adresse . . . . . . . . : 00-FF-AF-4D-05-27
Ethernet-Adapter Ethernet 5:
Beschreibung. . . . . . . . . . . : Kaspersky Security Data Escort Adapter #2
Physische Adresse . . . . . . . . : 00-FF-23-9F-6E-88
Drahtlos-LAN-Adapter WLAN:
Beschreibung. . . . . . . . . . . : Intel(R) Dual Band Wireless-AC 8260
Physische Adresse . . . . . . . . : 76-18-A5-4D-71-9C
Verbindungslokale IPv6-Adresse . : fe80::ed4f:2349:9a21:98bd%16(Bevorzugt)
IPv4-Adresse . . . . . . . . . . : 192.168.188.20(Bevorzugt)
Subnetzmaske . . . . . . . . . . : 255.255.255.0
Lease erhalten. . . . . . . . . . : Donnerstag, 25. Februar 2021 08:17:24
Lease läuft ab. . . . . . . . . . : Sonntag, 7. März 2021 09:02:42
Standardgateway . . . . . . . . . : 192.168.188.1
DHCP-Server . . . . . . . . . . . : 192.168.188.1
DHCPv6-IAID . . . . . . . . . . . : 276175013
DHCPv6-Client-DUID. . . . . . . . : 00-03-00-01-76-18-A5-4D-71-9C
DNS-Server . . . . . . . . . . . : 192.168.188.1
NetBIOS über TCP/IP . . . . . . . : Aktiviert
Ethernet-Adapter Bluetooth-Netzwerkverbindung:
Beschreibung. . . . . . . . . . . : Bluetooth Device (Personal Area Network)
Physische Adresse . . . . . . . . : E4-B3-18-CE-0D-00
@BM_9825484 wrote:
Hi!
  • disable all network card but one ... Intel(R) Dual Band Wireless-AC 8260
  • then remove all files from C:\ProgramData\PTC\Licensing directory
  • start reconfigure.exe from Creo Parametric\bin subdirectory (-OR- uninstall/install Creo)
Martin Hanák
Hi!
Thanks for your fast reply! I tried to do as you said but I still get the same result.
Do you have any other suggestions?
I also tried disabling the IPv6 Protocol. It didn't work either.
Then I tried using a LAN-cable and disabling all other network cards. Also didn't work.
I don't know if it is important for solving this problem but every license.dat file was empty.
@BM_9825484 wrote:
Hi!
maybe you can remove files from C:\ProgramData\PTC\Licensing directory and try installing Creo 7.0 - see below codes.
K-12 students can use Product code BE700908EDSTUDENTEDK12
University students can use Product code BK700908EDSTUDENTEDUNI
If Creo 7.0 is installed successfully, then you can use its license file to launch any previous Creo release.
Martin Hanák
Hey!
Thanks again for your answer but it still didn't work...
@BM_9825484 wrote:
Hey!
I give up. I do not know what is wrong with your computer.
Martin Hanák
I have the save issue, if you could help, I would be thanksful
Could you please give us more information?
Product code used, first install or relicense, name of the zip file downloaded...
Alex
Creo 6.0 Student Edition License says "Success!" but also "Invalid file or format
and my ip file is here
Windows IP Configuration
Host Name . . . . . . . . . . . . : DESKTOP-0VLRRSU
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Ethernet:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Realtek PCIe GbE Family Controller
Physical Address. . . . . . . . . : 80-CE-62-D4-16-21
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Wireless LAN adapter Local Area Connection* 1:
Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter
Physical Address. . . . . . . . . : 82-C5-F2-32-87-63
Wireless LAN adapter Local Area Connection* 2:
Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter #2
Physical Address. . . . . . . . . : 80-C5-F2-32-87-63
Wireless LAN adapter Wi-Fi:
Description . . . . . . . . . . . : Realtek RTL8723DE 802.11b/g/n PCIe Adapter
ALSO attach my license file thats no working after reset this pc
please help me how to manage this.
LICENCE FILE
#License Pack for Session ID 4767155
# PTC License Pack
#License codes for PTC Product.
#Cpu 80-C5-F2-32-87-63
#Contact : MAHESH KATARIYA
#Address :
#Email : maheshkatariya2000@gmail.com
######### Creo Student Edition Standard #########
#Feature Line Type = INCREMENT
#Feature Name = CREOPMA_Student6
#Feature Version = 37.0
#Version = Creo 6.0
#Number of Copies = uncounted locked license
#Supercede = Y
#Issue Date = 29-JUL-2020
#Expiration Date = 30-JUL-2021
#Node Locked Option = NOTEBOOK
#Node Locked Option = ASSEMBLY
#Node Locked Option = FEATURE
#Node Locked Option = DETAIL
#Node Locked Option = INTERFACE
#Node Locked Option = WLO
#Node Locked Option = SURFACE
#Node Locked Option = PLOT
#Node Locked Option = CABLING
#Node Locked Option = REPORT
#Node Locked Option = PIPING
#Node Locked Option = INTERFACE for STEP
#Node Locked Option = PHOTORENDER
#Node Locked Option = Student
#Node Locked Option = SHEETMETAL-DESIGN
#Node Locked Option = Mechanism Design License
#Node Locked Option = Behavioral Modeling License
#Node Locked Option = Import Data Doctor
#Node Locked Option = Design Animation
#Node Locked Option = Language Option - CHINESE
#Node Locked Option = Interactive Surface Design Extension Module
#Node Locked Option = Mechanism_Dynamics
#Node Locked Option = Advanced Rendering Extension 2
#Node Locked Option = Creo Freestyle Design
#Node Locked Option = Creo Flexible Modeling
#Node Locked Option = Creo Unite
#Node Locked Option = Mold Analysis Lite
#Node Locked Option = GDT Advisor
#Node Locked Option = Creo Render Studio
#Node Locked Option = Additive Manufacturing
INCREMENT CREOPMA_Student6 ptc_d 37.0 30-jul-2021 uncounted \
A08090D09D01CBE300A7 VENDOR_STRING="VSVER=2.0 \
LO=(0,6,7,10,17,19,32,34,48,51,61,69,73,110,115,127,128,135,137,155,188,191,283,325,326,336,347,354,357,361)" \
HOSTID=PTC_HOSTID=80-C5-F2-32-87-63 SUPERSEDE \
ISSUER=PTC-WEB-CREOSTUDENT6 ISSUED=29-JUL-2020 \
NOTICE="maheshkatariya2000@gmail.com, " SIGN2="1D7A \
E050 2F99 A897 702B 2573 5A71 57B2 6876 6EA4 F72D \
60E7 18A2 0F74 63AC 1BCB C42E 35BD EC94 4DA5 DB56 \
E593 7904 D4ED 31B3 E5E4 E7DD 6A69 CA4F 536C"
######### Creo Direct Modeling Education (Student) #########
#Feature Name = CREODMA_Student3
#Version = Creo 6.0
#Supercede = Y
#Node Locked Option = Pro/ASSEMBLY
#Node Locked Option = Pro/FEATURE
#Node Locked Option = Pro/INTERFACE
#Node Locked Option = Pro/SURFACE
#Node Locked Option = Pro/INTERFACE for STEP
#Node Locked Option = Language Option - CHINESE Educational
INCREMENT CREODMA_Student3 ptc_d 37.0 30-jul-2021 uncounted \
70F07060F16146453951 VENDOR_STRING="VSVER=2.0 \
LO=(6,7,17,19,32,69,110,155,326,336)" \
NOTICE="maheshkatariya2000@gmail.com, " SIGN2="19D7 \
8674 EE1E 7DD9 A5EB D7ED D2E3 5E79 EC70 A3A6 983A \
01FE 585B 80E2 71E1 11F2 49CB CE0C 5FE8 1188 EBF4 \
233E 05D8 2719 5F42 A506 ABB6 CD1E BB4C 0A5F"
######### Creo Layout Student #########
#Feature Name = CREOLAY_Student3
#Version = Creo 6.0
#Supercede = Y
#Node Locked Option = Creo Layout Module
INCREMENT CREOLAY_Student3 ptc_d 37.0 30-jul-2021 uncounted \
00B060F09C007E7424F8 VENDOR_STRING="VSVER=2.0 \
LO=(6,7,17,19,32,69,110,291,326,336)" \
NOTICE="maheshkatariya2000@gmail.com, " SIGN2="04C7 \
2B4A FC19 57C9 AAE5 DAA3 B666 86DF FEB0 1DC6 26CB \
F99D D353 00E1 D3D0 1334 D99A D8A6 8B6D A86E 49B0 \
775C 8823 1839 7D82 DFBC 8A4F 89BB E441 202B"
######### Creo Illustrate Standard #########
#Feature Name = CREOILLUS_STANDARD
#Feature Version = 6.0
#Version = Creo 6.0
#Supercede = Y
INCREMENT CREOILLUS_STANDARD ptc_d 6.0 30-jul-2021 \
uncounted C0905010038A9ABC0EB1 \
VENDOR_STRING="VSVER=2.0 LO=(19)" \
NOTICE="maheshkatariya2000@gmail.com, " SIGN2="0278 \
3254 3807 3817 C7EA 1311 318A 173C C885 F76B FDCD \
737A 46E0 479A C387 1802 0FA1 D572 DD04 D91B 66F4 \
7BDC 4E31 407F 39E8 3011 7EDD A4CF DFE6 E971"
I think your license is correct.
My suggestions related to network cards:
  • disable Microsoft Wi-Fi Direct Virtual Adapter (Physical Address: 82-C5-F2-32-87-63)
  • disable Microsoft Wi-Fi Direct Virtual Adapter #2 (Physical Address: 80-C5-F2-32-87-63)
  • connect to network using Realtek RTL8723DE 802.11b/g/n PCIe Adapter (Physical Address: 80-C5-F2-32-87-63)
Check parametric.psf file located in Creo_LOADPOINT\Parametric\bin sub-directory.
In line ENV=PTC_D_LICENSE_FILE-= you must see path to your license file.
You must see also ENV=CREOPMA_FEATURE_NAME=CREOPMA_Student6 () line.
Now you can try launching Creo.
Martin Hanák
