Hello, I'm a university student and I installed Creo 5.0 for students, after opening there was an error message saying license file not supported for this version. Creo exits after I close the error message. I opened the license file in txt and it appears to be a Creo 4.0 license for K12. Please help
did you enter Product code BE500806EDSTUDENTEDK12 during installation ?
Did you follow instructions mentioned in http://apps.ptc.com/schools/references/install_creo5_schools_standard.pdf document ?
I face the same issue few minutes ago. Indeed I used BE500806EDSTUDENTEDK12 when installing but when I tried to open Creo Parametric it says "licence request failed for feature" (see attached)
please enlarge error message window to see the complete information and post it again.
Error message tells us that Creo startup command is configured to use
C:\ProgramData\PTC\Licensing\BE410708EDSTUDENTEDK12_license.dat file.
It looks like you used Creo 4.0 before you installed Cro 5.0.
Go to C:\ProgramData\PTC\Licensing directory and look for BE500806EDSTUDENTEDK12_license.dat file.
If it is not present then I suggest you to:
If it is present then I suggest you to:
thx, now it works out
I had to uninstall and install again with BE500806EDSTUDENTEDK12
i recently installed creo 5.0 before that i used creo 3.0
i am unable to open the downloaded files in creo 5.0 student
showing that those files are made in commercial version and not compatible to open
in Student version it is vorbidden to open files created using Commercial license. Maybe you have access to Academic version in university lab ... this version is able to open "commercial" files and save them into format readable in Student version.
while opening creo 5.0 it is showing that license request failed for feature and license file does not support this version please help me go through it
