Creo 5.0 Student Edition can´t be installed (Windows 10)
Participant
Hello everyone,
I tried everything and search google as well, but I couldn´t find a solution. In short, setup.exe doesn´t respond (I tried all 3 setup.exe files, noone of them worked. Could you help me?
What I did is below:
1-) downloaded the program (MED-100WIN-CD-420_5-0-0-0_Win64.zip - 4.01 GB)
2-) deactivated the virus program
3-) extracted it with 7zip
4-) runned setup.exe as administrator (there were 3 setup.exe, I tried the other two as well, none of them worked)
5) tried it with compatibility settings as as well.
P.S: I also reinstalled Windows update for C Runtime.
Re: Creo 5.0 Student Edition can´t be installed (Windows 10)
1.] I use 7-zip 9.20 to unzip installation package
2.] try to launch setup.exe on different computer
3.] login as admin user
Martin Hanák
Hi Martin,
Thanks for the reply.
I tried the exact same file, which I downloaded and extracted with latest version of 7zip program before, on another PC. It showed the setup page without a problem. So, maybe my PC is missing some essential files.It is a (kinda) newly installed Windows 10 N (European addition).
Do you know which programs/files are essential for setup to work? Then, I can install them and try again later. Or should I try to do something else?
Edit: I login as admin user, btw.
Thanks again.
1.] I installed Creo on Windows 10 Pro and Windows 10 Home, only
2.] I think Windows 10 N is not supported
3.] I am sorry I do not know what is missing in Windows 10 N
Martin Hanák
Okay, thanks for the reply anyway. Smiley Happy
I think there is no difference between Windows 10 (Pro and Home) and Windows 10 N (Pro and Home) other than some pre-installed apps.
Have a nice day.
