Creo 5.0 Student License
Visitor
I followed the directions for install and license, however when I try to launch any of the Creo Application they return a license error, even though the license is located correctly. I would note that Creo Direct on launch just terminates without message where the other 4 applications return a license error, when I select OK the application(s) close
14 REPLIES 14
Re: Creo 5.0 Student License
Seems you dont have a student license for 5.0 is that correct ?
Hi, I have the same problem: I have both installed Creo 5.0 following the instructions provided from PTC and gone through the configuration process described by PTC in the "School Configuration Guide", although when I run the program it shows me a message that says: "License request failed for feature". I'm not an expert of computers and I have no clou what that means, if you know what the problem is could you please tell me and maybe suggest me what I can do to solve it?
Thank you
Please submit your request in "Academic Support Request" form: Academic Case Logger
I have the same license error. Has anyone found a solution?
if you want to install Creo Parametric 5.0, then:
1.] remove all files from C:\ProgramData\PTC\Licensing directory (move them into other directory)
2.] install Creo Parametric 5.0 and use Product code BE500806EDSTUDENTEDK12 to get Student license.
Martin Hanák
Thanks for providing solution. Awesome it worked...!!!!
Didn't work for me unfortunately
This license key did not work for me. Do you have any other solutions or keys?
did you follow procedures described in following documents ?
https://apps.ptc.com/schools/references/install_creo5_unistudent_standard.pdf
http://apps.ptc.com/schools/references/install_creo5_schools_standard.pdf
What error message did you get ?
Martin Hanák
Welcome to PTC Academic!
