Creo 5.0 Student License
Re: Creo 5.0 Student License
just do this
1) uninstall creo parametric 5.0 (only) and
2) remove licencing files permanently from your machine , from recycle bin also
2) go to setup again and start installing
3) in licencing use code:- BK500806ED0790-Y3M9-4RW5
4) enter your ID and password and click install
restart your machine
good to go
let me this worked for u or not
I spent three days emailing an advisor and with a specific code generated just for me and about 20 installations later with different licenses and my firewall off, I finally got the student version to work. (There was a conflict with a previous version of the software).
My project is due in two weeks and the student version is so limited that I can't use the features I need anyway. The student version files aren't backwards compatable, so version 5 files at home cannot be loaded on version 3 at university (not useful).
However, to everyone who helped me. I thank you all, this issue is resolved.
If you have any questions get in touch with Martin Hanak, hopefully he can help.
Good Luck
Tags (1)
Worked for me, thank you for the help!
yes
