Creo 5.0 error when installing.
SOLVED
Visitor
Can't find anything at all why it isn't installing. The only applications that install are Common Files and Diagnostic Tools. The licences are good fine, Anti-virus are off and its running with admin.
Re: Creo 5.0 error when installing.
Did you check the pre-requisites? Also try changing the installation location other than the default location.
6 REPLIES 6
unfortunatelly I do not know what is wrong with your computer.
I hope that you downloaded 4 GB zip file from PTC website and unzip it.
Try following:
1.] remove all pieces of unsuccessful creo installation
2.] create new admin account
3.] login into new admin account
4.] launch setup.exe
Martin Hanák
Tried this and didn't work. When I look at the more information icon it says "Prerequisite for Creo Parametric -- Creo 5 Platform Services -- is not satisfied. "
So what is solution for this problem anyone know? I have same issue. Thanks
Hey,
I am having the same issue and for all of those writing "did you check the prerequisites", People we are not dumb here. Also, why in God's name it mentions "SOLVED" in the forum when we all know there is no clear solution to it.
Best regards,
Sdixit4
Hi Dixit,
Let me try to help you out with the issue. Can you please send the screenshot of the errors?
