Creo 5.0 error when installing.
SOLVED
Visitor
Can't find anything at all why it isn't installing. The only applications that install are Common Files and Diagnostic Tools. The licences are good fine, Anti-virus are off and its running with admin.
Re: Creo 5.0 error when installing.
Did you check the pre-requisites? Also try changing the installation location other than the default location.
unfortunatelly I do not know what is wrong with your computer.
I hope that you downloaded 4 GB zip file from PTC website and unzip it.
Try following:
1.] remove all pieces of unsuccessful creo installation
2.] create new admin account
3.] login into new admin account
4.] launch setup.exe
Martin Hanák
Tried this and didn't work. When I look at the more information icon it says "Prerequisite for Creo Parametric -- Creo 5 Platform Services -- is not satisfied. "
So what is solution for this problem anyone know? I have same issue. Thanks
