Is it possible to install VBA functionality (vb_api_register.bat or whatever is what is necessary) on the student version of Creo 6.0?
Don't remember having the option to select it during the original set up but when I tried to "modify" the original installation to add VBA, the program went thru the motions and displayed an "all things successful" message box.
Thanks in advance.
I do not know if it is possible to add VBAPI into existing Creo installation.
So I suggest you to uninstall/install Creo.
Do not forget to click Customize button during installation and select VBAPI item in displayed dialog box.
