Creo 6.0 Student edition License error
Sekarbalaji21
1-Newbie
I have tried installing Creo 6.0 student edition, when i entered my username and password while installation, it showed "error". then i skipped the license registration and installation done. But now I cannot lauch the application -"License request failed for this feature" error and the app closes automatically.  Please help on this. Thanks in advance.
1 ACCEPTED SOLUTION
Most likely, if you got the error message you had copied the code with some blank spaces.
You can try to run setup.exe again, choose reconfigure existing software and type the correct code in the simple licensing field.
If you still get the error, please hold the mouse over the Error sign and it will tell you what went wrong.
Alex
1 REPLY 1
Alex
