Creo 6.0 student edition came with license key for creo 5.0
SOLVED
Visitor
Hello, I'm a university student and I installed Creo 6.0 for students, after opening there was an error message saying license file not supported for this version. Creo Closes exits after I close the error message. I opened the license file in txt and it appears to be a Creo 5.0 license. Please help
Re: Creo 6.0 student edition came with license key for creo 5.0
I followed the steps from the pdf thoroughly, but it still doesn't work. I've made a screenshot of the error window.
Kind regards
valid Product codes for Creo 6.0 follow ...
K-12 students can use Product code BE600908EDSTUDENTEDK12
University students can use Product code BK600908EDSTUDENTEDUNI
Also read carefully:
https://apps.ptc.com/schools/references/install_creo6_schools_standard.pdf
or
https://apps.ptc.com/schools/references/install_creo6_unistudent_standard.pdf
Martin Hanák
Kind regards
Hi  MatthiasP,
It seems to me that the Creo was licensed with an older version product code.
Solution is simple:
Run setup.exe of Creo 6.0 (from the unzipped folder) and choose Reconfigure existing software.
Use the Product code provided above for the version you need and finish the reconfiguration.
This will fix it.
Alex
Kind regards
unfortunatelly PTC installer is not very smart ...
The procedure mentioned in pdf file works well in situation when no Creo is installed and C:\ProgramData\PTC\Licensing directory is empty.
If Creo 5.0 is installed and you want to install Creo 6.0, too ... then you have to:
  • move Creo 5.0 license file from C:\ProgramData\PTC\Licensing directory in another directory temporarily
  • install Creo 6.0 using Creo 6.0 Product code
  • move Creo 5.0 license file back to C:\ProgramData\PTC\Licensing directory
If you follow these absurd play, then you can use Creo 5.0 and also Creo 6.0.
Martin Hanák
Tank you both very much, it works now.
Kind regards
Welcome to PTC Academic!
