When installing Creo, there are two main licensing errors you might encounter:
If you hover your cursor over the “Error!”, you should see a description of what went wrong.
Here are a few fixes to common mistakes:
If you drag the bottom corner of the Warning Message box to expand it, you will be able to see a description of the error.
Here are some common errors and ways to fix them:
If you’ve gone through the whole process above and are still having issues with licensing, create a new post on the community detailing your issue and make sure to include as much information as possible.
Abdul
