Creo Parametric license request failed
ptc-4415431
1-Newbie
My computer runs windows 7 64 bit and meets all of the specifications for Creo.
I have my product code, but everytime I run the setup wizard to generate the license it returns this:
A failure occured during license generation.
An unknown error occured requesting a license file be generated from ptc.com
I am using this software in an engineering elective at Univerisity of Alabama Birmingham.
1 ACCEPTED SOLUTION
Hello Josh,
i do not see any reqiests from you...can you please email me your PTC HOST ID and will create the license file for you.
thanks
Dima
9 REPLIES 9
Try to conract with "PTC Academic Support": http://www.ptc.com/go/academic-support
still having the same problem, contacted academic report several days ago and still waiting on a reply.
Hello Josh,
thanks
Dima
Good day, Dmitry
I downloaded Creo Parametric 1.0 Schools Edition quite sometime back. I had sent request for the lisence file, however no reply from anyone to date. Is it possible for you to create a license file for me, if I give you my PTC Host ID?
Sivaroopan
Hello, i also meet the same problems.
Can you help me to solve it?
Plz.........
Please contact the Academic Support team: http://www.ptc.com/go/academic-support
I'm having the same problem, and was wondering how I can get in contact with the Academic Support Team. I can't find an email address.
All Academic support should go through our PTC Academic Support page where you can find a solution yourself or submit a support request from the bottom of the Request Academic Support tab.
Thanks, Adam. I appreciate the help.
