Creo Parametric problem with start up
SOLVED
Newbie
Hi Community,
Excuse me for my bad english and my unknowledge about Creo, I am a newbie
I am a Student wich has to work with that software at home.
After install i have a problem now during starting the software : (translation :Creo will be closed because the quality agent can´t start. Code 0x00000002.
Do you have any ideas ?
Thank you very much,
CK
Re: Creo Parametric problem with start up
Hi CK,
This looks like a relatively common problem and we should be able to help you out. Please see the link below for more information on this problem and what you should do to fix it.
http://communities.ptc.com/thread/44531?tstart=0
Thanks!
Mark
Moved this discussion to our community, so our team can help.
Hi CK,
Thanks!
Mark
Welcome to PTC Academic!
