Creo Platform Agent Unsuccesful
SOLVED
Newbie
Im attempting to install creo, creo common files, and several others, installed fine, however it failled to install creo platform agent. In the installation manager it simply says "unsuccesful"
Re: Creo Platform Agent Unsuccesful
12 REPLIES 12
try following steps:
  • uninstall all Creo items
  • create new admin account
  • login as new admin
  • select setup?.exe file, press right mouse button and use As Administrator option
Martin Hanák
Hi Martin,
Having this same problem while trying to install 4.0 for students on the latest version of windows 10.
please tell us what actions have you done.
Martin Hanák
Thanks for replying,
I have followed the following steps:
1. Registered for Creo 4.0 Student Edition.
2. Followed the link to http://apps.ptc.com/schools/references/install_creo4_schools_standard.pdf#_ga=2.256790345.354699836....
3. Downloaded and unzipped MED-100WIN-CD-410_M030_Win64
4. Ran the setup executable as an administrator
5. Followed the PTC instillation assistant until reaching Application Instillation
Please see attached image for instillation assistant result.
how did you unzip MED-100WIN-CD-410_M030_Win64.zip file ?
Suggestion: Use 7-zip 9.20 for unzipping.
What to do ...
  • uninstall all Creo 4.0 components (to locate them easily in program list, sort the list by date in Installed On column
  • do not clean C:\ProgramData\PTC\Licensing directory ... it must contain valid license file (its name contains BE410708EDSTUDENTEDK12 text)
  • install Creo 4.0 from scratch ... do not enter Product Code, instead of it put the path to license file into field in Source column (maybe the path will be already available there)
Martin Hanák
Hi Martin
Yes I used 7zip to uninstall the folder.
Still no luck installing the software with your recommendation.
Please see attached file for all the steps I followed.
Kind regards,
Iain
unfortunatelly I do not know what is wrong on your computer 😞
Suggestions:
1.) uninstall Creo 4.0 items marked on following picture
2.) uninstall PTC Diagnostic Tools item
Prepare different installation directory. If I were you I would create PTC subdirectory in D:\ and CR4_M030 subdirectory in PTC. My installation path would be D:\PTC\CR4_M030
3.) If you place mouse cursor on "i" button, you will see error message. Please do it.
Martin Hanák
Hi
I had the same problem, couldn't install CREO 4.0. The first line in the installation window software tries to install CREO Platform Agent, if unsuccessful it will not install the rest of the components.
I installed first PTC CREO 4 Platform services (in my case C:\Download\MED-100WIN-CD-410_M060_Win64\install\addon\creosvcs_64.exe), that way CREO Platform Agent 4 was installed, after that CREO 4.0 install was successful.
Lukasz
I got the same problem.
Did you resolve it ?
Thanks ^^
please open new discussion and describe your problem using more details.
Martin Hanák
I ended up installing 3.0 and then installing 4.0
this issue disappeared, however i kept getting a licence issue when opening the program.
Welcome to PTC Academic!
