Creo Student 3.0 M190 crashes Quick Tables
CB_5278556
3-Visitor
I want to use the Quick Tables utility to make an assembly drwing, but when I click on the Quick Tables tab, I got an error message and Creo crashes immediately.
The message says that the file "bom_description_bom.tbl" was created with a commercial version of Creo, and I am using an educational version.
I am using Creo Parametrics Student Edition 3.0 M190.
I could do the same thing with an older version of Creo Student 3.0, but I can't remember wich build it was.
Does anyone know how to solve this problem? I can't use a newer version of Creo.
1 ACCEPTED SOLUTION
The only way to use them is to change the license you are using now.
You can run setup.exe, choose reconfigure existing product and in the licensing window, click the minus "-" in front of the existing license and use, in the simple licensing, the code:
BE400407EDSTUDENTEDK12
Then simply complete the process.
This should allow you to use the commercial formats.
Alex
1 REPLY 1
Alex
