Creo doesn't start
AKree
1-Newbie
Creo doesn't start
First sorry for my english, i'm french.
I'm student and I have school edition of Creo 2.0
I have tried to install creo 2.0 on Windows XP, Windows 7 & Windows 8. Now i'am on Windows XP Pro.
I had problem with Creo 2.0, when i want start creo parametric just after install creo, Creo does not start.
I have tried to change mode 256 colours and to activate OPEN GL. Also I have tried to uninstall Quality Agent & reinstall this, but all things we haven't find the solution of my problem.
Do you any idea to help me ?
Thank you for the time you will spend on my problem.
9 REPLIES 9
jsarkar
1-Newbie
(To:AKree)
would you try to install on another machine with windows xp pro?
AKree
1-Newbie
(To:jsarkar)
No, because i'm in training and i have just one computer for me.
Dale_Rosema
(To:AKree)
Is the machine and graphics card on the approved list for Creo 2.0?
http://www.ptc.com/WCMS/files/135225/en/creo2_hw_notes.pdf
Thanks, Dale
In machine equip with Windows XP I'm not sure for the graphic card.
But when I have setup Creo 2.0 on machine equip with windows 8 and nvidia card ( good configuration), the same problem arrived.
I'm very disappointed because when i click on the shortcut of parametric nothing arrived. If click on parametric.exe nothing arrived too.
StephenW
23-Emerald II
(To:AKree)
PTC has a dedicated group for academic support, have you tried that. I think this is a common problem and they can probably help you quickly.
http://www.ptc.com/appserver/wcms/forms/index.jsp?&im_dbkey=142574&icg_dbkey=482Academic Support
and a forum for academic support too:
http://communities.ptc.com/community/academic-program/support
qzhou-2
(To:AKree)
If you use integrated Intel (R) graphics, please refer to https://www.ptc.com/appserver/cs/view/solution.jsp?n=CS156839 for a possible workaround.
AKree
1-Newbie
(To:qzhou-2)
Thank you Stephen Williams2, i look this after my work.
Qimin Zhou, I can't go on your link because i haven't the "right" to reach at this part, because i have student account.
If possible to copy what you want what i'm see in this link, on this subject ?
Hey Mehdi -
As STEPHEN WILLIAMS2 suggested, you should talk with the team in our community. I've moved this discussion there so that our team can take a look and get back to you.
They will most likely ask you to fill out a Academic Support Request so they can give you some 1-on-1 support.
Best,
- Ryan
Ok, i send a request .
I have made some research in Academic support part and i find this: http://apps.ptc.com/schools/references/support_creo2_graphics.pdf . I have tried to make everthing this document say, but nothing work.
