Creo file for missing Tetrix part - W41789 - servo bracket
lstewart
1-Newbie
Does anyone have a Creo part file for the flat servo mounting bracket that is a part of the W41789 mounting kit. It doesn't seem to be in the KOP provided. Here's the link to the Tetrix part: TETRIX® MAX Standard Servo Mounting Kit (W41789)
Thanks for you help!
Linda
1 ACCEPTED SOLUTION
smorris
(To:lstewart)
Linda Stewart‌, hot off the Pitsco press. The attached ZIP contains Creo CAD files for the items included with W41789 - TETRIX® MAX Standard Servo Mounting Kit.
  • Servo Bracket
  • Shaft Coupler
  • D Shaft
  • Bushing
3 REPLIES 3
smorris
(To:lstewart)
Linda, that is a new part from Pitsco. I don't remember seeing it before. I will put in a request with PTC to update their KOP with Pitsco.
smorris
(To:lstewart)
  • Servo Bracket
  • Shaft Coupler
  • D Shaft
  • Bushing
Awesome! Thank you Pitsco and Scott!
