Exploded View Settings
dzulkiewski
1-Newbie
I just created an exploded view of a car with 4 wheels and when I clicked on the exploded view icon everything shifted to the left. I was hoping the wheels and rims would explode outwards away from the car.
How do I change the settings for exploded views?
1 ACCEPTED SOLUTION
You can edit the position of parts in your saved exploded view.
  1. Model ribbon > Model Display group > Manage views.
  2. In the dialog, select the Explode tab and, in the list, select the exploded view you want to change then click the Edit button. From the drop-down menu, select Edit position..
  3. Select a part or sub assembly and you will see dragger arrows which you use to re-position it.
  4. When you have finished re-positioning all the parts click the green tick/check button in the ribbon and close the dialog.
2 REPLIES 2
