Falsche Links für Creo3-Download auf PTC-Homepage
BergMax
Guten Tag,
nach der Registrierung auf der Seite "http://www.ptc-de.com/de/academic-program/academic-products/free-software/creo-college-download" gelangt man zu einer Seite ("http://.../thank-you"), auf der die Installationsanweisungen für unterschiedliche Versionen verlinked sind.
Hier erhält man aber für Creo 3 einen falschen Link zur Installationsanleitung der Schools-Edition und nicht zur Student-Edition. Eine Installation der Student-Edition ist ohne den erforderlichen Produktcode aber nicht möglich. Bitte möglichst bald korrigieren...
1 ACCEPTED SOLUTION
FYI ... creo3 will run with a creo5 license.
Martin Hanák
4 REPLIES 4
FYI ...
If you can install Creo 5.0 you will receive license file. Later you can use this file during Creo 3.0 installation.
Creo 5.0 product codes
K-12       students can use Product code BE500806EDSTUDENTEDK12
University students can use Product code BK500806ED0790-Y3M9-4RW5
See also attached PDF documents.
Martin Hanák
BergMax
(To:MartinHanak)
Wow, what a solution..Smiley Frustrated
Instead of downloading ~4Gig for Creo3 now in addition ~4Gig for Creo 5.
Hm, after creation of license file in Creo5-setup, it should be possible to cancel setup without installing the complete creo5.
But the feature name in different versions of creo student-editions are not the same. So I think creo3 will not run with a creo5 license.
No, that's no solution.
But meanwhile I found the correct link and the correct productcode for C3 in the www.
There are so many misstakes/differences between the german ptc/de and the english ptc/en hompages.Smiley Sad Maybe PTC will do its homework somtime.
Thank for the "try"
Martin Hanák
BergMax
(To:MartinHanak)
Oh, that's new.
I tried to run Creo2 with a Creo3 license and that did not work.
So that has been changed by PTC - good to know, thank you.
