GCRI and .neu is not working
SZ_9648586
3-Visitor
Hello everyone, I have a problem: for academic work I need to work on Creo 5.0 while i'm working at university labs, but on my PC I have Creo 3.0, which i'm using for other work. Is it possible to save a file in creo 5 so it's possible to open and work with Creo 3 after ? I tried to install Creo 5 on the PC but it seems it has problems. It is possible to have two versions of Creo working on the same PC (both academic licences) GCRI Method and .neu is not working
Creo 3.0 Academic can't open any Creo 5.0 files. The only possible way is to install on your home computer Creo 5.0 (this will not affect your Creo 3.0).
You will need to uncheck during installation the Creo 3.0 license in the Creo 5.0 installer (licensing window) and use the code for Creo 5.0.
Alex
