Graphics slow on many different computers
Re: Graphics slow on many different computers
The easiest fix is to replace the card with a compatible one. I'd still recommend using the process explorer. It has a GPU tab to examine GPU usage. As it is not supported by PTC I don't see any resolution to the problem unless you happen on a compatible driver. Depending on the Machine brand the driver from Intel may be incompatible.
Latest from Intel https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=24348&lang=eng&ProdId=3720
Typical stats as part of identifying performance problems:
Machine brand
OS
CPU
GPU (as noted already)
GPU Driver version
Creo Version/datecode
Windchill/other PDM Version/datecode
All, Intel 4400 problem solved by up grading to Creo 3 M010.
Welcome to PTC Academic!
