Having trouble with licensing
SOLVED
Newbie
Hi all,
I just downloaded Creo 2.0 and when i try to enter the license in the 'simple license entry' box, I am unable to select the box itself to type anything in. I was wondering if this maybe a local issue or if there is a fix. I am also having this problem when i try to install 3.0.
Thanks in advance.
Tags (2)
Re: Having trouble with licensing
Hi Ganesh,
You can find a guide that shows the soltuion to this problem here: http://communities.ptc.com/thread/44525?tstart=0
Please let me know if i you have any questions!
Hi Ganesh,
Welcome to PTC Academic!
