How to download the creo 4.0 student version .pls send the link to download the software
Bhaskar123
2-Guest
Am trying to download the software of creo 4.0 student version but I can't to do it in since 3 days .pls send the link to download the software.
11 REPLIES 11
gvalley
6-Contributor
(To:Bhaskar123)
newstudent
(To:gvalley)
Thank you for your post, I have downloaded Creo version 4.0 and have installed it, however when I open it I get a message "license request failure". I checked in C:\ProgramData\PTC\Licensing  for the license file and it is there BE410708EDSTUDENTEDK12_license, this is the license the program loads up. But apparently the installed program is not recognizing this file as the license file.
In a previous post I requested another license file which I got "sw_license_email_4015076". I dropped this .DAT file into the same folder above and that one does not work either.
Is the standard CREO 4.O version the student version? Is there a product code I should be using for the student version? that matches the license file?
1.]
According to my knowledge base BE410708EDSTUDENTEDK12 is Creo 4.0 Product code.
2.]
If you open BE410708EDSTUDENTEDK12_license.dat file you will see a couple of INCREMENT blocks
I think the file contains line similar to the following one
INCREMENT CREOPMA_SchoolSTD4 ptc_d vv.0 dd-mm-yyyy \
3.]
CREOPMA_SchoolSTD4 is the name of Creo Parametric license
vv.0 is license version ... for Creo 4.0 you need 35.0 or higher
dd-mm-yyyy is license end date
4.]
License file path and license name is mentioned in parametric.psf file located in Creo4_LOADPOINT\Creo 4.0\Mxxx\Parametric\bin directory. Open the file in Notepad and check/correct following lines.
ENV=PTC_D_LICENSE_FILE-=absolute_path_to_BE410708EDSTUDENTEDK12_license.dat_file
ENV=CREOPMA_FEATURE_NAME=CREOPMA_SchoolSTD4 ()
Martin Hanák
Which link do you use?
the only one link I know is mentioned in http://apps.ptc.com/schools/references/install_creo4_unistudent_standard.pdf document.
http://www.ptc.com/appserver/auth/it/esd/academicFree.jsp
is translated to
https://support.ptc.com/appserver/auth/it/esd/academicFree.jsp
User have to create user account at PTC Support to be able to access download page.
Go to https://support.ptc.com/appserver/support/account/my_account.jsp
Martin Hanák
Am trying to download the software of creo 4.0 student version but I can't to do it in since last week .pls send the link to download the software.
I down loaded Creo 6.0 by mistake two weeks ago.
My teacher told me that we are using 4.0 so I should down load that instead. I uninstalled 6.0. I installed 4.0 on Tuesday.
Now when ever I go to open the 4.0 I get the error message; "License request failed for feature" and " Invalid feature name" (FEATURE_NAME)
Can you assist me in opening your program?
Thank you,
Don Redmon
replikad@gmail.com
Student at Cabrillo College
Santa Cruz, Ca.
Thank you,
Don Redmon
replikad@gmail.com
Santa Cruz, Ca.
look into C:\ProgramData\PTC\Licensing directory. I hope you will find there license file related to Creo 6.0. You can use this file to run Creo 4.0.
Suggestion:
1.) uninstall Creo 4.0
2.) install Creo 4.0 ... do not enter Product code, instead of it put path to license file into Source field
Martin Hanák
Hi Martin,
 As you suggested I uninstalled version 4.0.
I have been trying to down load 4.0 from the PTC site. https://www.ptc.com/en/academic-program/academic-products/free-software/creo-college-download/thank-you
I have been getting this for about half and hour.
Invalid URL
The requested URL "[no URL]", is invalid.
Reference #9.c5f33f17.1581560371.3b98ab98
WTF!!!
Don Redmon
@replikad wrote:
Hi Martin,
Invalid URL
WTF!!!
Don Redmon
to download 4 GB zip file, go to https://support.ptc.com/appserver/auth/it/esd/academicFree.jsp page and use HTTPS link to start download. Also you have to login using your PTC account.
Note: When download is finished, you have to unpack zip file before your launch setup.exe
BTW ... did you find license file in C:\ProgramData\PTC\Licensing directory ?
Martin Hanák
