I installed as per guideline which is provided in site but also Creo parametric is not opening.
It is showing this error at a time of opening creo parametric:- "Creo parametric Student Edition (for education use only) is sutting down because it could not run the Quality agent, which is required in this edition." and also showing "Creo angent did not initialize correctly"
Re: I installed as per guideline which is provided in site but also Creo parametric is not opening.
try following:
  • uninstall PTC Quality agent
  • reboot PC
  • install PTC Quality agent using <INSTALL_PACKAGE>\install\addon\qualityagent_64.msi
Martin Hanák
I followed step is given by you in earlier email about Unistall
PTCqualityagent file and install another Qualityagent file after reeboot
but also this type of error is coming.
On Sun, Sep 27, 2020 at 12:36 AM ADROJA PUJAN RAJESHBHAI <
17bme006@nirmauni.ac.in> wrote:
please publish picture showing details of your steps. I need to know exactly:
  • what item did you uninstall
  • what package did you install
Martin Hanák
Hi @PA_9623813,
You can share snapshots as asked by Martin. Also, you may try disabling anti-virus (if there is any) during re-installation and see if it helps.
Rahul Ghadge
Welcome to PTC Academic!
