Hello ladys and gentlemen,
first of all, i want to apologize for my bad english.
I'm a student from germany and i'm currently working on my technician project.
I already designed a 3D model of my machine in Autodesk Inventor 2020.
There are problems with importing both of the autodesk inventor files (.ipt and .iam) into Creo Illustrate Professional 6.0.
I attached the error log from Creo.
Maybe someone can help me with my problem.
Best regards
Marco
Best regards
Marco
I guess that the answer is very simple ... in Creo Illustrate 6.0 the ability to open Autodesk Inventor 2020 file is not yet implemented. Usually it takes several months to implement the ability to read new file format.
On https://www.ptc.com/en/support/refdoc/compatibility/technicalgraphicscompendium_168055 page there is a link to PDF file containing Technical Graphics Compendium. On page 7 I can see this
Please try importing the assembly in Creo Parametric first and save it from there as a PVZ. Illustrate works great with PVZ and Creo Parametric can import you assembly and convert it to PVZ.
Alex
thank you for the quick answer.
We don't have Creo Parametric in our partnership package.
But I Think this wouldn't be the solution i looked for anyway.
I saw youtube tutorials, where Autodesk Inventor files were linked directly in Creo Illustrate.
The advantage is that i can change my 3D model in Inventor and i have directly the updated
model in Creo Illustrate.
Do you have another solution for my problem?
I mean there is the option to directly import Autodesk Inventor.
Best regards
Marco
You can use "STEP" file format as an option.
Good morning,
STEP file is working but i have to touch up the model again in CREO .
This is not the best solution for me anyway. I have to update my 3D-model in Inventor.
There is the possibility to link Inventor models. The linked models should be automatically updated
when i save the new Inventor file. Why is it not working?
Best regards
Marco
There could be many reason for that, starting from license missing the tool to allow importing to incompatibility (educational/commercial between the software).
I'd like to try to solve your problem, so could we move the conversation on email? Please send me an email on acazacu@ptc.com
Alex
Best regards
Marco
Ohh that's too bad. This should be the problem. Unfortunately i looked over it.
I guess i have to try to get an older version of Inventor and try to import my model there first.
Thank's for your help.
P.S. Is there already a date, when Autodesk Inventor 2020 Files are implemented in Creo 6.0?
unfortunatelly I do not know when Autodesk Inventor 2020 file format will be recognized by Creo. I guess it will be Creo 7.0, not 6.0.
