Install errors
SOLVED
ptc-5165880
Newbie
Install errors
I am a FIRST FTC mentor of a rookie team and struggling with installation. Using the install from web option. I have my firewall off and am running as administrator. When I try to generate a license code it tells me invalid and to contact support. When I try to use the license code I rec'd in the email I get the following error message. Very frustrated and I would love some help with this...
Re: Install errors
Hi Kristin,
A lot of the time the installation assistant will become "non-responsive" if it is the being run as a "web installer". My recommendation to you would be to download the full DVD (found here as Win 32-64 DVD (4478 MB)) and then run the installation from there. If this does not fix the problem, please let me know!
Re: Install errors
Hi Kristin,
Re: Install errors
Kristin,
It might also help to follow the installation instructions detailed here after downloading the DVD from the link Mark provided.
Hope this helps!
Chris
Re: Install errors
Thanks! Downloading it in the DVD format worked perfectly. We were also able to store the downloaded software onto a USB flash drive and install it on all of the teams laptops without having to re-download it over the internet. The directions were clear and concise frmo that point forward!
Thanks again,
Kristin Clemons
Mentor FTC Team #7037
Welcome to PTC Academic!
