I tried to install Creo 2.0 but each time stoped at "Applications" step as the installation was not listing applications. I tried the following steps as described below.
Step 1: Downloaded the "Creo2_setup.exe" and double clicked on it.
Step 2: Selected "Install new software" and pressed "next" at the right bottom corner
Step 3: Accepted license agreement by selecting "I accept the license agreement" and pressed "next" at the right bottom corner.
Step 4: Entered my user name "mxislam2@wichita.edu" and password and selected "Log In"
Step 5: Entered my product code in "Install Licensing" and license file was available in "License Summary" and pressed "next"
Step 6: Applications step. The applications were not populating and "install" button was grayed out and I was stopped there. I tried couple of times with rebooting but couldn't change anything.
Please help me to solve this.
Hi Mohammad,
This seems like an issue with the installer. Can you give me a link from which you downloaded it from?
I would recommend using the following link if you are not already...
Hi Mohammad,
