Installation problem.
gimoesemi
1-Newbie
Hello
Pls am trying to install creo 3.0 for students but I have an issue. I cannot place the installation key in the provided box because the mouse cannot highlight it. I need help pls so I can start learning.
1 ACCEPTED SOLUTION
Hey there,
I had the same problem, but for me it turns out I needed to run the "setup-schools.exe" file instead of the standard install file. This version of the install should simply ask for username and password and generate the installation key automatically. Worked for me, but now I can't get the program to actually launch on my son's computer. We'll get it figured out!!
Good luck,
Scott
2 REPLIES 2
Hey there,
Good luck,
Scott
I figured i did not run it as an administrator. So i had to first extract it to a folder before installing it as an administrator.
