I know the PTC team would feel unloved if they didn't hear from me at least once on kickoff day
First off, kudos for making AE235100-0160_2012.asm a mechanism!
Second off, kudos for putting mass into the models!
Now the non-kudos
Lastly, there were whispers about a Library being created for the KOP this year that would be accessible in Windchill. Did that not happen?
Overall, not bad!
Thanks guys,
Josh
Thanks Josh for the heads up. We will have these addressed immediately.
Reagrds,
Mark
Whoops, one more problem. fe-00035_iam__levelofdetail3_.asm in the Field_Assembly is a ghost part as well.
Reagrds,
Mark
Thanks Mark!
It amuses me that I get to set your response as the "Correct Answer"
