Licence error Creo 2
pbrown
1-Newbie
Hi All,
All of a sudden we have lost the connection to our Creo 2 server with this licence error.
I have tried to reconfigure the installation on our server using the reconfigure.bat but all instances of inputting the licence number are greyed out, I have tried disabling the Antivirus etc but without success.
Any ideas??
We are using the student Academic edition.
Many thanks in advance.
1 ACCEPTED SOLUTION
Many thanks Mark and Jayanta for your prompt replies,
I fell like a bit of an idiot.
Investigating furthur I found out our PTC Sever was rebooted because of an outage and the Creo 2 Server software had not restarted so I restarted and presto all is good again!
There is a big lesson to be learnt in all of this....First check to see if the server is running via the PTC Licenece Server Tools in All Programs/PTC/PTC Licenece Server Tools and on the tab Start/Stop/Reread, start the Server!
This helped me..and if your problems looks like mine? It may save you a lot of heartache.
Paul
4 REPLIES 4
jsarkar
1-Newbie
(To:pbrown)
I guess you need check the lan connection, try to ping the server ip adress from the command prompt first, then check firewall etc.
MarkCheli
6-Contributor
(To:pbrown)
Hi Paul,
I agree with Jayanta, it sounds to me more like an issue of connectivity between the server and the client computer rather than a direct licensing problem.
Do you see the old license file during the "Licensing" stage of reconfiguring the license server? If possible can you include a screen shot of that step of installation?
Thanks!
Paul
Hello there Mark, could you take a look at this post? You might be able to give us a hand...
http://communities.ptc.com/message/247892#247892
Thank you very much!
