License issue with Creo 3
SOLVED
Newbie
I installed Creo 3 with the provided license key, and I'm getting this error when trying to run it. I'm not really sure how to fix this.
1 ACCEPTED SOLUTION
Highlighted
Re: License issue with Creo 3
Michael,
A sure fire way to fix this is to go to the folder: C:\ProgramData\PTC\Licensing and delete all the licensing files there.
Now reinstall Creo and you should be all fixed.
7 REPLIES 7
Me too. Exactly the same issue.
Hi Shreyas,
Did you have Creo 2.0 installed on your computer before? I think this might have something to do with it.
Thanks!
I currently have 2.0 and am updating to 3.0 as we speak.
I never saw that problem though.
BTW: I am using the college/university link, maybe the issue is K-12 link only?
Cai,
It depends if you deselect the old Creo 2.0 license while installing or not. If you do , there should be no problems but if you don't then it will come up with this error.
I also have the same issue
Highlighted
Michael,
Just FYI, C:\ProgramData is usually a hidden folder. The first part of this guide shows how to unhide it:
http://apps.ptc.com/schools/references/support_programdata.pdf
Welcome to PTC Academic!
