License not found
jousefmrd
License not found
Hi there!
Just installed the academic version of Creo Parametric 6.0.2.0 but the license cannot be found. I got a license pack via mail and want to know where to put the file in?
Thanks in advance! 🙂
1 ACCEPTED SOLUTION
@jousefmrd wrote:
Hi there!
  • launch reconfigure from Creo's Parametric/bin sub-directory
  • in License Identification dialog box in License Summary section enter path to saved license file into Source field
  • finish reconfiguration
Martin Hanák
12 REPLIES 12
Martin Hanák
jousefmrd
(To:MartinHanak)
Hi Martin, is this supposed to be a hyperlink?
@jousefmrd wrote:
Hi there!
Martin Hanák
jousefmrd
(To:MartinHanak)
Hey Martin!
Thanks for your response. Just checked and there is no reconfigure file as far as I can tell. Does it have a specific name?
Martin Hanák
Again ... I wrote my replay in Internet Explorer and ... entered text disappeared.
So I have to remember that Lithium powered PTC Community web does not work in IE anymore !!!
If you can't find reconfigure
then uninstall/install Creo.
During installation do not enter Product code and ... in License Identification dialog box in License Summary section enter path to saved license file into Source field.
Martin Hanák
You can also simply run setup.exe (from the folder you installed Creo) and select reconfigure existing software in the first tab. This will do the exact same thing as reconfigure.exe, but for all the software parts (Parametric, Direct, Layout...).
Alex
jousefmrd
(To:Alex_Cazacu)
Thanks guys!
However it does not work. I also typed in the academic license key but it won't accept the key, that's so odd...
please upload license file mentioned in original text. I will check its contents and let you know, what to do (I hope).
Martin Hanák
jousefmrd
(To:MartinHanak)
#License Pack for Session ID 4085690
# PTC License Pack
#License codes for PTC Product.
#Cpu E4-B9-7A-23-AB-03
#Contact : XXX
#Address :
#Email : XXX
######### Creo View MCAD Educational #########
#Feature Line Type = INCREMENT
#Feature Name = PVMCADPRO
#Feature Version = 11.0
#Version = Creo 4.1
#Number of Copies = uncounted locked license
#Supercede = Y
#Issue Date = 12-OCT-2019
#Expiration Date = 12-OCT-2020
#Node Locked Option = WLO
INCREMENT PVMCADPRO ptc_d 11.0 12-oct-2020 uncounted \
50A0E0605CF288A80915 VENDOR_STRING="VSVER=2.0 \
LO=(19)" HOSTID=PTC_HOSTID=E4-B9-7A-23-AB-03 \
SUPERSEDE ISSUER=PTC-WEB-CREOEDUSTD5 \
ISSUED=12-OCT-2019 NOTICE="XXX, \
" SIGN2="0AB8 5EFF 7934 8106 0A97 34B6 1C67 C899 \
1077 1992 A1CC 5A14 DEB7 A359 EA16 12A4 CFAF 46D4 \
3FDA EA75 20C8 E0C9 72FB 61A2 0EBA 4906 900F BCEE \
D4D1 3B9A"
######### Creo View Base Educational #########
#Feature Name = PVPRO
#Version = Creo 4.1
#Supercede = Y
INCREMENT PVPRO ptc_d 11.0 12-oct-2020 uncounted \
107090707C0A6DB25D36 VENDOR_STRING="VSVER=2.0 \
" SIGN2="1F74 7625 6F06 188D F746 E1FD F30C 6BC6 \
04AC AB73 9985 B5E0 D26C 3922 2D7C 12DC E1EA 9DEF \
E55E 69CE A90A 0F2A D9B9 D3E2 60BD A02B 568C A083 \
C581 DECC"
######### Creo Direct Modeling Education (Schools) #########
#Feature Name = CREODMA_Schools3
#Feature Version = 36.0
#Version = Creo 5.0
#Supercede = Y
#Node Locked Option = Pro/ASSEMBLY
#Node Locked Option = Pro/FEATURE
#Node Locked Option = Pro/INTERFACE
#Node Locked Option = Pro/SURFACE
#Node Locked Option = Pro/INTERFACE for STEP
#Node Locked Option = Educational License
#Node Locked Option = Language Option - CHINESE Educational
#Node Locked Option = Creo Flexible Modeling
#Node Locked Option = Creo Unite
INCREMENT CREODMA_Schools3 ptc_d 36.0 12-oct-2020 uncounted \
60E0B0B088BB43A50222 VENDOR_STRING="VSVER=2.0 \
LO=(6,7,17,19,32,69,136,155,326,336)" \
HOSTID=PTC_HOSTID=E4-B9-7A-23-AB-03 SUPERSEDE \
ISSUER=PTC-WEB-CREOEDUSTD5 ISSUED=12-OCT-2019 \
NOTICE="XXX, " SIGN2="08EA 2BC0 \
0E45 604B 0A11 53AD C419 8467 25AB 32EC C741 A990 \
4649 3665 F465 08A1 A312 C9D8 55DF AC4E 3007 BB84 \
DF8D 29FE 0F16 095B C738 CD3C 2B32 D057"
######### Creo Layout Schools #########
#Feature Name = CREOLAY_Schools3
#Version = Creo 5.0
#Supercede = Y
#Node Locked Option = Creo Layout Module
INCREMENT CREOLAY_Schools3 ptc_d 36.0 12-oct-2020 uncounted \
70C07020DDE81140FDDB VENDOR_STRING="VSVER=2.0 \
LO=(6,7,17,19,32,69,136,291,326,336)" \
NOTICE="XXX, " SIGN2="0188 DE01 \
344D 4F57 623A 89CE CC08 F855 32AF 2E86 6145 FC99 \
F916 7355 A47B 0ADB 20C7 6DBA 4A95 DC68 43AB A4A0 \
34A4 7BC1 4796 C44E C91C CC7A C419 BA5D"
######### Creo Parametric Schools Standard #########
#Feature Name = CREOPMA_SchoolSTD3
#Version = Creo 5.0
#Supercede = Y
#Node Locked Option = NOTEBOOK
#Node Locked Option = ASSEMBLY
#Node Locked Option = FEATURE
#Node Locked Option = DETAIL
#Node Locked Option = INTERFACE
#Node Locked Option = SURFACE
#Node Locked Option = PLOT
#Node Locked Option = CABLING
#Node Locked Option = REPORT
#Node Locked Option = PIPING
#Node Locked Option = INTERFACE for STEP
#Node Locked Option = PHOTORENDER
#Node Locked Option = SHEETMETAL-DESIGN
#Node Locked Option = Mechanism Design License
#Node Locked Option = Behavioral Modeling License
#Node Locked Option = Import Data Doctor
#Node Locked Option = Design Animation
#Node Locked Option = Interactive Surface Design Extension Module
#Node Locked Option = Mechanism_Dynamics
#Node Locked Option = Advanced Rendering Extension 2
#Node Locked Option = Creo Freestyle Design
#Node Locked Option = Mold Analysis Lite
#Node Locked Option = GDT Advisor
#Node Locked Option = Creo Render Studio
#Node Locked Option = Additive Manufacturing
INCREMENT CREOPMA_SchoolSTD3 ptc_d 36.0 12-oct-2020 \
uncounted 00C050005B76720DAA9C \
LO=(0,6,7,10,17,19,32,34,48,51,61,69,73,115,127,128,135,136,137,155,188,191,283,325,326,336,347,354,357,361)" \
NOTICE="XXX, " SIGN2="010F E6BD \
F700 ABEE FF6F 97E6 7F46 A478 A165 CAA9 D152 BC5F \
1720 6AA5 CE0D 0D93 F47A 3D64 7B91 AB7B 260C 9112 \
93DA 7831 99ED 27DD 5484 BBCA AF93 B26C"
your license file contains following comment lines
#Version = Creo 5.0
They tell you that license file enables you to run all Creo releases up to 5.0.
License file does not contain code that would allow you to launch Creo 6.0.
My suggestion:
1.] uninstall Creo 6.0
2.] move all files from C:\ProgramData\PTC\Licensing directory to another directory to get empty C:\ProgramData\PTC\Licensing directory
3.] install Creo 6.0 ... use correct Product code, see below
K-12 students can use Product code BE600908EDSTUDENTEDK12
University students can use Product code BK600908EDSTUDENTEDUNI
Also you can read:
https://apps.ptc.com/schools/references/install_creo6_schools_standard.pdf
https://apps.ptc.com/schools/references/install_creo6_unistudent_standard.pdf
Martin Hanák
Setup.exe -> Reconfigure software
Yes, that did it finally - thank you
