License problem with running Creo4.0
SOLVED
Level 6
We are a new FTC team and are trying to install Creo4.0 for the first time. Everything seems to work fine and install is successful. When opening Creo for the first time a warning message comes up:
Warning Message list
License request failed for featureRequesting CREOPMA_SchoolSTD3...
C:\ProgramData\PTC\Licensing\BE400407EDSTUDENTEDK12_license.datSmiley Sad-1) Cannot find license file.
I have tried navigating the Licensing folder and placing the .dat file there. I have viewed some of the other solutions from previous similar questions and I am unable to follow those directions. They generally say that from the PTC Installation Assistant point the license to the correct file at the "License" tab - something like below:
https://community.ptc.com/t5/PTC-Academic-Program-Discussions/Creo-4-0-Problem-with-installation/td-...
When I run setup-schools.exe file I do get the PTC Installation Assistant, but Licences is not a tab on the left as in previously solved questions and Setup Licenses is greyed out. I can only select "Install new software" even though I just finished installing (and uninstalling...installing...uninstalling...installing while trying to resolve this issue) . It asks for login information and successfully installs. Then when I go to openit I get the same error.
Not sure what to try next to resolve. Any help would be appreciatedSmiley Happy
Re: License problem with running Creo4.0
if you want to use Creo 4.0, then
  • move all license files from C:\ProgramData\PTC\Licensing somewhere else
  • uninstall Creo 4.0
  • launch setup.exe from Creo 4.0 installation media
  • enter Product code
K-12       students can use Product code BE410708EDSTUDENTEDK12
University students can use Product code BK410705EDSTUDENTUNICL
Martin Hanák
Martin Hanák
This worked!
Thanks.
Worked for me too.
Thank you!
Worked for me too,
Thank you!
