License request failed for feature (Creo 5.0
Dijan02
3-Visitor
Creo 5.0 parametric opens to the message below:
Requesting CREOPMA_SchoolsSTD4
c:\ProgramData\PTC\Licensing\BE410708EDSTUDENTK12_license.dat:(-1) Cannot find license file.
I used the code given on the instructions and another one found in a thread form ptc help, neither has worked. I've downloaded and installed the program several times and am still getting this message. Before installing I've deleted the previous attempts license file from the c drive.
Any help resolving this issue would be greatly appreciated.
did you follow these steps ?
1.] uninstall all Creo items
2.] remove all license files from C:\ProgramData\PTC\Licensing (see step 2. in install_creo5_schools_standard.pdf document)
3.] install Creo
Martin Hanák
BE410708EDSTUDENTK12 product code belongs to Creo 4.0, only.
To install Creo 5.0, K-12 students can use Product code BE500806EDSTUDENTEDK12
Please follow insctructions included in http://apps.ptc.com/schools/references/install_creo5_schools_standard.pdf
Martin Hanák
I've followed those instructions several times with the code, BE500806EDSTUDENTEDK12, and it produces the same failed result.
I have three install options:
Setup
Setup-schools
setup-trial
Per the instructions I used "setup.exe," the first option. During the installation process I used the student code given in the instructions, BE500806EDSTUDENTEDK12.
If I downloaded Creo 5.0, why would the program be looking/requesting  a Creo 4, code?
3.] install Creo
Martin Hanák
