I am mentoring team 3316 in israel. I covered with the kids modeling and assembly basics. now i want to take them to the next level of showing off their work with some rendering and animations.
I am looking for a good tutorial\tutorials on the subjects (couldnt find in the plms).
does anyone know where can i find it?
Itzik,
It isn't very fancy but I threw the attached document together, showing the quick workflow for rendering your designs. I hope it helps.
http://apps.ptc.com/schools/render_robot.pdf
Adam
Itzik,
Adam
Nice pictures Adam! Looks like you got Scot and John in there too!
I really don't have time for this but could not resist. The PTC robot in front of PTC corporate in Needham
That little robot sure gets around!
Sunshine, green grass and trees! Much more used to seeing everything coated in snow and ice out there!
A few links:
"Introduction to Advanced Rendering Extension (ARX)":
1. http://www.ptc.com/go/wildfire/learn/tutorial_2161/index.htm
2. http://www.ptc.com/go/wildfire/learn/tutorial_443/index.htm
3. http://metalab.uniten.edu.my/~judha/ARX%20Workshop%20Tutorial.pdf (from: http://metalab.uniten.edu.my/~judha/Eng_Graph.html)
4. http://communities.ptc.com/message/172818
"Pro/E Design Animation Tutorial":
1. http://www.eng.buffalo.edu/~llee3/Projects/DesignAnimationTutorial_2010.pdf
