Is there a way to mirror a sub asm in my main asm ?
thanks
Creating mirrored subassembly in main assembly:
Insert>Component>Create - select Type > Subassembly / select Sub-Type > Mirror
Insert new name for your new subassembly > click OK.
(You can define Geometry/Placement dependecies)
Select source subassembly and mirror plane. In new window is possible define new-name for subassembly components.
Complete operation: press OK button.
