Not running creo 2.0 student edition though installed successfully on my core to duo 64 bit operating system.
Nothing happens i.e. no any errors or anything message when click on creo parametric 2.0 icon on desktop.
I had installed creo 2.0 student edition as per PTC guideline & also it successfully installed without any error...
my system configuration is:
Processor : intel core to duo E8200 @ 2.66 GHz
RAM : 4 GB
Windows 7.0 with service pack 1.0
Kindly guide ASAP
Dnyaneshwar
Hi MarkCheli,
After updating system drivers online now Creo 2.0 is running well. chill..
But though I would like to fill the form for future reference.
Thanks for your kind support..
Dnyaneshwar Maid
Hi Dnyaneshwar,
Typically this happens when Creo is installed with some kind of anti-virus or other security software enabled. My recommendation would be to do a full uninstall first, then re-install and make sure to do the following...
If this does not work please let me know!
Dear MarkCheli,
Hi.. & Thanks for your reply,
I tried as per your suggestion but still it is not working.
While Installing everthing is going ok, but after clicking on desktop Icon nothing is happening.
nothing means no any message, errors etc. hence didnt getting what is wrong happening?
please guide further..
Dnyaneshwar
Hi Dnyaneshwar,
I think the best way to go from here is to do a remote session so that I can more directly take a look. Could you please fill out the form from the link below:
http://www.ptc.com/appserver/wcms/forms/index.jsp?&im_dbkey=142574&icg_dbkey=482
That way we will be able to get in contact with you privately and make arrangements.
Hi MarkCheli,
Dnyaneshwar Maid
I am having the same problem :
I would really appreciate your help
Reme Martínez
Hi Reme,
Have you tried...
Full uninstall first, then re-install and make sure to do the following...
YEs i've tried and is is stilll not working
Can you fill out the below Academic Support Form:
http://support.ptc.com/appserver/wcms/forms/index.jsp?&im_dbkey=142574&icg_dbkey=482
This will allow us to get in contact with you more quickly to resolve this issue.
I'm facing the same problem for Creo 3.0 student edition. I have filled the Academic support form. Please suggest a solution.
