PTC Creo 7.0 - Student Edition
OB_9667600
I am currently installing the PTC Creo 7.0 - Student Edition. I'm following the Quick installation guide.
I am entering the simple licence code "BK700908EDSTUDENTEDUNI" as indicated and click "Install license". Now I am asked to enter my username and password. At this point the installation program always gives me the error "Authentification failed". The username and password are entered correctly!
Can anyone help me at this point?
I've sent you a private message with the reset password. I'd assume that there is some error in the password of your account (not generated by you).
Alex
16 REPLIES 16
type username and password into Notepad (to be sure that the y are correct) and then copy&paste them into login window.
Martin Hanák
thanks for the answer, but unfortunately it doesn't work. Same error as before.
My username and password are entered correctly.
maybe you can try installing in English environment:
  • open Command prompt window
  • enter command ...  set LANG=english
  • enter command ... your_directory_path\setup.exe
  • now you can see English installer (I hoppe)
Martin Hanák
Same error, different language
I have no other idea ...
Maybe the problem is related to the fact that users recognized serious problem in Creo Parametric 7.0.1.0 and PTC removed this version from download area used by commercial customers. It seems to me that PTC forgot to remove this version from download area used by academic community. I hope that @Alex_Cazacu  can look at your problem.
Martin Hanák
Alex
that worked!
Thanks a lot for your help!
Hi
I have a similar problem. He typed everything correctly, there is even a success with logging in, but the release of the program pops up with a license error 😞 will you help me?obraz_2020-10-13_213151.png
@OZ_9662899 wrote:
Hi
your license file contains Creo 6.0 license. It cannot be used to run Creo 7.0.
Please read following documents slowly and carefully:
https://apps.ptc.com/schools/references/install_creo7_schools_standard.pdf
https://apps.ptc.com/schools/references/install_creo7_unistudent_standard.pdf
Martin Hanák
HELO
I also had this type of fear, because I received a similar instruction on email when you linked me, only for creo 6. I had to enter the same action, but a different code. It is the same with the rest of the proceedings. I also had to reinstall creo 7 but it worked. Thank you very very much MartinHanak 😉
I just have one more question. The simulation module is not active in CREO 7. Is that normal for the student version because I thought it was available in this version? 🤔
Student license file does not contain full Creo Simulate license. Only Creo Simulate Lite functionality is available.
I hope @Alex_Cazacu can provide information which student product you need to buy to have access to Creo Simulate.
Martin Hanák
There are 2 Creo student editions: Free Standard that you are using and Premium that can be purchased from the https://store.ptc.com/
The free student edition has Simulate lite and the Premium has full (student) Simulate.
Alex
Could you please send me the reset password. I have the same problem, basic password reset doesn't work for me.
Thank you,
Klara
Hello together,
I have the same probleme. Could you send me the reset password too?
Thanks and best wishes.
Benji
MartinHanak
24-Ruby II
(To:Benji)
@Benji wrote:
Hello together,
Benji
please use following URL to reset your password.
https://www.ptc.com/appserver/common/account/password.jsp
Martin Hanák
