ProDesktop Help
Newbie
ProDesktop Help
The help files in Pro-desktop seem pretty comprehensive - but I cannot find the following! On creating an engineering drawing from ProDesktop file, there seems to be no way of editing the title block at the bottom right of the sheet. How can this be done? Many thanks Tom Carr
RE: ProDesktop Help
The title block is defined within the drawing template. These are found in Program Files/PTC/ProDESKTOP 8.0/Program/Drawing Formats. For example, the file A2.dra contains the drawing boarder and title block text which is used in Template3.dra. It is in the file A2.dra that you can edit the title block text. the file Template6.dra contains text which explains how the title block can be filled in automatically. More information on creating drawing tempates can be found in the Help under Formtats and Templates.
Welcome to PTC Academic!
