Problem isntalling creo elements student edition
ptc-4181020
I've just purchased and downloaded creo 5.0 student edition.
The downloaded file for win/64 was only 191MB. After unzipping and running install nothing happens!!! -no error codes, no student edition screen.
anyone have an idea (I'm running win7 64)
thanks
11 REPLIES 11
Julian,
Sorry you are having this problem. Try downloading the entire installation DVD at http://apps.ptc.com/schools/Creo_ElementsPro_Student_DVD.zip. This image will support both 32 and 64bit.
This is a large download, approximately 3.6GB so unless you have a very fast connection, I would suggest you use a download manager such as Free Download Manager, this will allow you to stop and restart the download if necessary.
Adam
Thanks alot!
I am downloading from the link now. I hope it works.
Best regards
Julian
I have downloaded the files from the link now...
I have tried running the setup file directly from the folder and also to mount it as an image on a virtual drive first. The only thing that happens is that it loads for a few seconds and then nothing!
Julian,
Have you unzipped (extracted) the file to a folder or are you trying to run the setup before unzipping? It must be extracted first, to a folder named "Creo_ElementsPro_Student_DVD". After extracting it, you can delete the zip file and work from the folder.
If this doesn't work, please email - so that we can get this taken care of.
Adam
Yes I have unzipped the package and named it "Creo_ElementsPro_Student_DVD". no luck!
-and no reply from - since the 2nd dec. 😞
Hi Julian,
What type of machine are you installing this on? What operating system and graphics?
Please provide the specifications of the machine so we can diagnose the issue further.
Mark
Hi Mark
I’m using windows 7 professional 64bit service pack 1 on a PC.
Processor: intel core2 quad cpu q9300 @ 2.50GHz 2.50GHz
Memory 8GB
Graphics: GeForce 260 GTX
Best
Julian
Hi Julian,
I would like to connect to your machine an take a look. Can you please send me your email address to -?
Mark
I have the same problem... On my laptop it is running without any problem 😞
Hi Jonas,
Can I connect to your machine?
Mark
thanks for your support! Now I am using a new windows installation and everything is fine. I guess it was a problem with my OpenGL driver oder something simliar...
best regards
jonas
