Problem with the revolve tool
ptc-5082891
Newbie
I have a problem when I want to make the revolution of an area that I have defined in the sketch.
I get the following error: "This function is defined with very small dimensions compared to the rest of the piece. Is advisable to change the precision of the part to be less than 0.000304513."
Please, how do I fix it? I do not know where to change the precision of the part...
Thank you very much.
Tags (2)
1 REPLY 1
Re: Problem with the revolve tool
It is likely that you sketch has a very small line or other entity (with respect to the entire sketch). For a new user, this could simply be a case of not being familiar with using Sketcher.
If this small entity is by design, you could fix it by making it larger before revolving it, then editing the completed feature to be the size you want after it has been revolved.
Welcome to PTC Academic!
